Saimon's avatar
Saimon
Router issues
Hi,
I am having issues my router.If I restart/reboot my router,the router lost the memory and I have to re setup the router from beginning.
Also i am not getting full signal and sometimes keep disconnecting the device.
Anyone can help or advise me what should I do.My warranty already expired more than one year ago.
Thanks in Advance
  • plemans's avatar
    1. you have the r8000?
    2. what firmware is on it?
    3. what modem/gateway is it connected to?
    4. "not getting full strength". describe this more in details. what speeds are you getting? over 2.4ghz? or the 5ghz?
    • Saimon's avatar
      Saimon
      I m using NBN ( FTP)
      2.4ghz getting 45-60 mbps
      My internet speed 200mbps but not getting that speed
      Firm ware v1.0.4.74
      Model no :R8000
      • plemans's avatar
        Saimon wrote:
        I m using NBN ( FTP)----that just tells me your in australia and you have fiber to the premises
        2.4ghz getting 45-60 mbps----thats actually a good speed over 2.4ghz. 2.4ghz is a slower network and sensitive to interference. There's a lot of misunderstanding about realistic speeds over wifi. You can read here for more details. : Understand Wi-Fi 4/5/6/6E (802.11 n/ac/ax) (duckware.com)
        My internet speed 200mbps but not getting that speed---what wired and 5ghz speeds are you getting?
        Firm ware v1.0.4.74
        Model no :R8000
