bdesai1222
Apr 12, 2014Follower
Router Keeps Rebooting
Router R7000 keeps rebooting by itself. Called netgear, replaced product twice but eventually ends up in same situation. Sometimes works for days and then all of sudden Router keeps rebooting by itsel...
- Apr 19, 2016
Hi Prime40633 and rowe100,
I would suggest contacting support team as it might be a hardware issue.
docwitteman
May 03, 2017Initiate
I have found my r7000 cycles when I try to connect my laptop by wifi. Works fine with all other devices just goes out with laptop
May 03, 2017Guru - Experienced User
What is the Mfr and model # of the laptop?
What is the Mfr and model # of the wireless adapter in the laptop?
Which radio is the laptop conecting too? 2.4 or 5Ghz?
What security modes are you using? Try WPA2 and AES only.
Set up to 300Mb on both radios.
Manual channel 11 on 2.4ghz and 48 on 5Ghz.
What FW version is loaded on the R7000? Have most recent version loaded?
