bdesai1222
Apr 12, 2014Follower
Router Keeps Rebooting
Router R7000 keeps rebooting by itself. Called netgear, replaced product twice but eventually ends up in same situation. Sometimes works for days and then all of sudden Router keeps rebooting by itsel...
- Apr 19, 2016
Hi Prime40633 and rowe100,
I would suggest contacting support team as it might be a hardware issue.
Tom535
Sep 17, 2014Initiate
I have experienced the same problem, it continuously drops the wan connection, wifi network and reboots by itself. This issue has heavily increased using the later software versions and the latest one is totaly unusable. So I downgraded and tested my way down and have found the V1.0.3.24_1.1.20 to be the latest most stable version and it also states in the release notes that it's wifi certified and contains stability fixes. So far all my problems with dropped networks and reboots is gone. To me the reboot issue is a serious bug in the software that Netgear need to fix..
