bdesai1222
Apr 12, 2014Follower
Router Keeps Rebooting
Router R7000 keeps rebooting by itself. Called netgear, replaced product twice but eventually ends up in same situation. Sometimes works for days and then all of sudden Router keeps rebooting by itsel...
- Apr 19, 2016
Hi Prime40633 and rowe100,
I would suggest contacting support team as it might be a hardware issue.
innovate
Oct 17, 2014Aspirant
Same issue. The re-boots are random. The logs do not show any errors, preceding the re-boot, the Log just shows that the router was initialized.
Firmware version is V1.0.3.80_1.1.38 which I upgraded to a couple of weeks ago. I'm not sure if this is when the problem started but it sure is coincidental.
The suggestion above that it could be a power glitch / surge is possible, but I would have thought the router would be fairly tolerant of dirty power as they are designed for home use, where the power is not clean (like a datacenter for example)
Advice above suggests reverting to V1.0.3.24_1.1.20.
I have a support call out with Netgear and if no joy from this I think I will revert to V1.0.3.24_1.1.20.
Would welcome any other advice / comments
