bdesai1222
Apr 12, 2014Follower
Router Keeps Rebooting
Router R7000 keeps rebooting by itself. Called netgear, replaced product twice but eventually ends up in same situation. Sometimes works for days and then all of sudden Router keeps rebooting by itsel...
- Apr 19, 2016
Hi Prime40633 and rowe100,
I would suggest contacting support team as it might be a hardware issue.
Podsy
Nov 01, 2014Aspirant
I had the same problem when I connected an external hard drive to the router.
There seems to be an issue with the USB ports on this router.
Look at the issue people are having with NAS and corrupting hard drives.
Called Netgear somewhere in India I am sure and they told me they do not support file transfers. That is a different issue. I would unplug anything plugged into this router and see if it keeps rebooting on you.
