bdesai1222
Apr 12, 2014Follower
Router Keeps Rebooting
Router R7000 keeps rebooting by itself. Called netgear, replaced product twice but eventually ends up in same situation. Sometimes works for days and then all of sudden Router keeps rebooting by itsel...
- Apr 19, 2016
Hi Prime40633 and rowe100,
I would suggest contacting support team as it might be a hardware issue.
Staudie
Jan 13, 2015Aspirant
I had an issue about a week ago which required me to build the router. I used the reset factory, flash firmware, reset factory method. Since then the router will reboot every 4 days at ~6:30am. I dont think its a dirty power issue since the unit is connected to an APC UPS. I would like to replace it but it seems from previous posts the problem is firmware related. Any idea what I need to do to fix the issue... the router is driving me crazy with all problems.
Thanks
Staudie
Thanks
Staudie
