bdesai1222
Apr 12, 2014Follower
Router Keeps Rebooting
Router R7000 keeps rebooting by itself. Called netgear, replaced product twice but eventually ends up in same situation. Sometimes works for days and then all of sudden Router keeps rebooting by itsel...
- Apr 19, 2016
Hi Prime40633 and rowe100,
I would suggest contacting support team as it might be a hardware issue.
bflobills
Jan 14, 2015Aspirant
I too have had numerous random router re-boots. Sometimes up to 10 times per day, then okay for a few hours and then another.
I contacted TS who told me all the normal things to try such as factory resetting etc. I did the 30-30-30 reset with the latest FW, (before and after) but it still happened.
One thing I am trying now is to turn off both up and down QOS which others have mentioned success with - we'll see.
Also disconnected my Magic Jack to see if that's the problem. It's only been 2 hours since I did this with no re-boots so far, so too early to tell but I will report back if things improve.
