bdesai1222
Apr 12, 2014Follower
Router Keeps Rebooting
Router R7000 keeps rebooting by itself. Called netgear, replaced product twice but eventually ends up in same situation. Sometimes works for days and then all of sudden Router keeps rebooting by itsel...
- Apr 19, 2016
Hi Prime40633 and rowe100,
I would suggest contacting support team as it might be a hardware issue.
bflobills
Jan 21, 2015Aspirant
I think this problem has to do with ipv6 lease. If you cmd to find out when the lease expires, I bet the router will re-boot shortly after that time - mine does like clockwork.
I am trying to disable ipv6 to see if that changes.....
