Beekmans-online's avatar
Sep 29, 2016
Router login troubles R7000
I bought a second-hand Netgear R7000. When I tried to connect to this router via routerlogin.net it shows a site with the text "Detecting if there is an existing router in your network, please wait". It keeps detecting on and on. It won't continue.
I have tried a reset to factory settings but it didn't help.
I have tried a firmware update by TFTP and it says "No responce from server"
Can anyone please help me?
Thanks
  • My problem occur when I try to login via a Mac (mac OS Sierra).
    I tried a Windows PC and had no trouble logging in.
    Once I changed the IP-address, from the router, to a static one I could logging from my Mac too!!!
    So, every one thank you very much for thinking.
  • Open browser and enter 192.168.1.1 into the URL location and if you get a prompt for a userID and password use admin and password, that should get you in. If not, try 192.168.0.1 and see if that works.
    Doesn't, open a CMD prompt and enter IPCONFIG /ALL and look at the Gateway IP Address. If it isn't one on the above, try that.
    • I did those things already. I keep getting this annoying message. It seems like the router can't take this hurdle.
      My router has IP 192.168.1.1 and I have 192.168.1.2
      • VE6CGX's avatar
        VE6CGX
        Master
        The router may not be in router mode. Reset it before trying to do anything.
