lottathought
Mar 14, 2015Novice
Router randomly blocking websites
This is one of the stranger things that I have ever seen. My router is connected to the internet...and I can get to the internet...at least some of it. It is blocking certain websites however. ...
- Mar 22, 2015
The most imortant part of the MAC address change process is that you power cycle the modem (the router also if you want, but particularly the modem). If you don't do this the MAC address change at the router will simply kill your Internet connection. More often than not this fixes the issue of unreachable websites, which more often than not is nothing to do with the router (whatever the brand).lottathought wrote: I did try your suggestion Searay..in fact I tried several combinations....nothing.
tedl2
Jan 03, 2016Initiate
I have the same problem, and set a ticket up with Netgear, They wanted DNS set to 8888 but that didn't fix it. They then wanted ping data. The sites time out. Having done all this other guy did, this looks like a router issue.
JamesGL
Jan 05, 2016NETGEAR Employee Retired
Hi tedl2,
Have you tried the suggestion of Andy?
