haw1144
Mar 15, 2014Follower
Router won't connect to internet (Comcast modem) anymore
I've had this router for a few months without any issues. But this morning all my connected computers said limited connection.. I'm still on the network but no internet available. I've tried unplu...
- Mar 15, 2014
haw1144 wrote: Any ideas/suggestions?
Since you seem to be getting an Internet connection just fine when connecting a PC wired to the modem I would recommend that you try to spoof the MAC of that PC. Simply do this:
From the PC that you are able to reach the Internet when connected directly to the modem, connect a cable to one of the four LAN ports on the R7000. Log in to it via http://192.168.1.1/ with admin as username and password as password. Click Advanced and choose Setup -> Internet Setup. Make sure everything is set to automatic/dynamic and at the last option for Router MAC Address you choose Use Computer MAC Address. Click Apply and wait for the page to return. It should get right back to working now!
If it's still not working, please tell us how the Internet LED light on the front of the router is lit (the globe).
Clark_Griswald
Mar 16, 2014Aspirant
Resetting the modem has not been a choice in my experience. Comcast resets the modem with a new ip, and comcast modem will only allow R7000 to work as an access point. I have not found any way to turn the wireless transmitter OFF on any of the three comcast modems (i.e. device webgui) I have had in the past four months. Wireless transmitter must be turned OFF by comcast.
If anyone has found a way to access and control the modem, please post your findings.
Clark
Clark
