haw1144
Mar 15, 2014Follower
Router won't connect to internet (Comcast modem) anymore
I've had this router for a few months without any issues. But this morning all my connected computers said limited connection.. I'm still on the network but no internet available. I've tried unplu...
- Mar 15, 2014
haw1144 wrote: Any ideas/suggestions?
Since you seem to be getting an Internet connection just fine when connecting a PC wired to the modem I would recommend that you try to spoof the MAC of that PC. Simply do this:
From the PC that you are able to reach the Internet when connected directly to the modem, connect a cable to one of the four LAN ports on the R7000. Log in to it via http://192.168.1.1/ with admin as username and password as password. Click Advanced and choose Setup -> Internet Setup. Make sure everything is set to automatic/dynamic and at the last option for Router MAC Address you choose Use Computer MAC Address. Click Apply and wait for the page to return. It should get right back to working now!
If it's still not working, please tell us how the Internet LED light on the front of the router is lit (the globe).
Clark_Griswald
Mar 16, 2014Aspirant
searay wrote: 10.0.0.1 admin password
"Been There & Done That"
Limited control and no ability to control wireless transmitter, or use comcast equipment as modem only, so R7000 is only router on network.
Thank You for trying. You are more informed then the comcast tech support.
This forum is a significant help for myself and others avoiding the uneducated corporate tech support lines.
Thanks to All & Have A Great Day-
Clark
