AngelaV
Feb 09, 2017Aspirant
"routerlogin.net" keeps saying I must be connected to my router's WiFi, even though I am
I was having connectivity issues with my Verizon Fios router. They sent out a technician and the problem was fixed. After my netgear wifi router was reset, I attempted to go to "www.routerlogin.com" ...
- Feb 22, 2017There was a white cable running from the FIOS to the NetGear. It's showed in the old pictures. The new pictures is how it's currently configured and it's worked like a dream since the removal of the white cable.
So to anyone with the same issues as mine, check your cables and make sure there aren't extras. All that's needed is the Ethernet cable connecting the FIOS router to the NetGear and the plug in from the NetGear to the outlet. Make sure you reset when removing a stray, unnecessary cable. It worked for me.
michaelkenward
Feb 09, 2017Guru - Experienced User
AngelaV wrote:only to get the messge, "You are not connected to your Router’s WiFi network. To access routerlogin.net, your device must be connected to your Router’s WiFi network. Check your current connection and try again."
This might be interesting:
Solved: Re: "routerlogin.net" keeps saying I must be conne... - NETGEAR Communities
As I read it, JamesGL, a moderator, is saying the the error message is wrong. Nothing to do with wifi.
This may also be useful:
Solved: Router not connecting to network - NETGEAR Communities
It says there:
I realized today that I had hardwired it to the computer but also was accessing it via wireless. There was a conflict. As soon as I disconnected the hard wire everything fell into place.
