harveybirdman's avatar
Dec 03, 2022
Setup for connecting two routers (R7000 & XR1000)
Hi, I'm super confused on how I should be properly setting up a second router. I have my modem, two routers (R7000 & XR1000) and PC all wired. Ideally I'd like both routers to support the same wireless network (e.g. one SSID). Here's a quick diagram showing my setup and the ports I plugged into: https://imgur.com/a/7fn1cDq
After plugging it in, my internet on my PC is working without changing any settings. But I have two wireless networks. If I go to routerlogin.net it only lets me connect to my R7000. Same with on my phone, even if I'm connected on my phone to the XR1000 wireless, it won't load the XR1000 router settings. I can only access the XR1000 settings if I unplug everything except the ethernet straight to the PC.
So my questions are:
1. Am I plugged into the right ports? (see diagram)
2. How do I sort out having just a single wireless network?
3. For the wired network, should I be putting something into AP or bridge mode or something else or doing some DHCP/IP settings, or can I leave it since it seems to be working?
4. Is there an easy/proper way to access the settings pages on two routers at the same time?
Thanks
    • harveybirdman's avatar
      harveybirdman
      Thanks FURRYe38  and Kitsap . I've swapped around the R7000 and XR1000 and it seems to be working.
      Only remaining problem is how do I access the dashboard of the R7000 now? If I go to routerlogin.net it brings me to the XR1000 dashboard. I tried unplugging everything and plugging the R7000 direct to the PC and then going to routerlogin.net/192.168.1.1 but it wouldn't load.
      • FURRYe38's avatar
        IF you put the R7000 in AP mode, look at the XRs connected devices list and see if the R7000 appears there, if so, look at the IP address. Use this IP address to access the R7000 in AP mode. One could set a static IP address of 192.168.#.70 on the R7000 so you'd know always how to access the R7000 while in AP mode. I recommend setting a Default DHCP IP address pool range of .100 to .200 on the XR router as well.
  • For your Ethernet connections.  Output of your modem should connect to the WAN input of your primary router.  One of the primary router output ports should connect to the WAN input port on your other router configured as a wired access point.
    Don't know why you have your XR1000 connected downstream of your R7000.  I second FURRYe38 recommendation to set your XR1000 as the primary router connected to your modem and configure your R7000 as an access point.
