LeeH's avatar
LeeH
Prodigy
Jan 06, 2017
Setup R7000 in Bridge Mode
I upgraded my R7000 firmware from 1.0.4.28 to 1.0.7.6.  I had my R7000 setup as a bridge before the upgrade.  I logged into the router after the firmware update and the bridge setup now has its own s...
  • ElaineM's avatar
    Jan 06, 2017
    LeeH Do you have the screen below? Once you have selected Bridge, there should be a button that says "Setup bridge mode wireless settings".
    Once you have selected that then a pop-up window should appear to input the settings.
