Bhmartin
Nov 23, 2019Tutor
Setup/software Upgrade
I was given a R7000 router by my sister. It was set up previously by "the cable guy." My sister never did anything with it except connect to WiFi. She never registered it with NETGEAR or set up the N...
- Nov 24, 2019
Bhmartin wrote:
I tried entering http://192.168.1.1 . I just got a message that said the server timed out. I also tried the reset. No luck there, either. Thanks for the suggestions.When you try the reset method, push and hold for 7-10 seconds while powered on. The lights should flash or change. that'll indicate a successful reset.
Bhmartin
Nov 24, 2019Tutor
Nov 24, 2019Guru - Experienced User
- BhmartinNov 24, 2019TutorThank you microchip8 and plemans. I had been pressing the reset button, but I wasn’t holding it down long enough. Once I got the router to reset, it still took some work because the software update wouldn’t work automatically. I had to bounce back and forth between routerlogin and the Nighthawk app, but I eventually got it working. Thank you!
