fdhsf's avatar
fdhsf
Slow download speeds
Hello, I have a r7000 router for my 1 gbps connection but I can´t get the full speed in wired in my company router I have full speed in speedtest.net I usually have 200 to 500 mbps I tried to downgrade the firmware to other version with the same result, router reset to stock values. I have a cat 6 cable, I tried to activate qos and wmm with the same result, I tried to change lan port 1-4 speed just increase 20 or 30 mbps. In router statidistics shows 1000m/full. That´s all, thanks for your comments.
  • fdhsf's avatar
    fdhsf
    Jul 27, 2018
    Yes my company router is in bridge mode and r7000 in router mode.
  • FURRYe38's avatar
    I believe that the R7000 may not have HW CutThrough handling for 1Gb ISP services. The 1000Mb on the RJ45 ports is a connection rate only of the Connection between the phsyical cable between the modem and router. Data throughput is different. If you did a full factory reset and set up from scratch and didn't enable QoS, Traffic Meter or any access controls and can't see near 900Mb+- non a wired speed test, I presume this router may not support it. I believe the R7800 does.
    • fdhsf's avatar
      fdhsf
      I can´t see any higher speed than 450 mbps with all disabled, qos, trafic meter and circle.
      • myersw's avatar
        myersw
        Master
        Probably time for an upgrade.
        One of the things folks overlook when upgrading Internet service is that the existing equipment might not be up to the task. I would think that the r7800 called out in previous message would handle it. Install Voxel firmware and should be good to go. Just make sure that what you get you can return if it turns out to not be up to the task.
    • DukeAVW's avatar
      DukeAVW
      I have an R7000 (main home router) with Gigabit AT&T Fiber and I get 950+ Mbps down/up via wired connections to our two desktop PC's. The hardware is capable of handling gigabit.
      • FURRYe38's avatar
        What version of FW are you using?
        What ISP modem/ONT are you using?
