Double0
Apr 08, 2022Aspirant
slow ethernet connection r7000
I recently had 1Gbps fiber ethernet installed and I get that speed when my computer is attached directly to the cable company's box. But when I plug my computer into my router (R7000 Nighthawk) it drops down to 200Mbps.
I have up-to-date software and firmware. I reset the router to factory settings etc and no change.
My connection is ethernet cable (cat5), not wireless. So there should be no slowdown when going through the router.
Any suggestions on what to look for?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?CAT5 doesn't support 1000Mbps connection rates. CAT6 is recommended and supports up to 10Gb connection rates.
- Double0Aspirant
Thanks FURREYe38 for the details.
Firmware is V1.0.11.134_10.2.119 I just downloaded it today.
The ONT is iPhontonix Model 7477G
I didn't know cat5 doesn't support 1Gbps, I'll have to get a cat6 wire.
From what I could find on that ONT, it has its own integrated router. It causes a double nat. (not necessarily your slow downs through)
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Modeto fix your slow downs, make sure the r7000 has qos, access control, traffic monitoring, and parental controls all disabled. If you've ever had them enabled, factory reset the router and start back at stock. during the install DO NOT enable those features. the r7000 is a 9 year old router and when those features are enabled, it disables ctf (cut through forwarding) which is needed to hit gigabit speeds.
