Th3-0n3's avatar
Th3-0n3
Tutor
Jan 12, 2019
Slow wifi speed.
I have a netgear cm1000 for the modem connected to my netgear nighthawk R7800 router my service is with comcast/ xifnity 400 download 10 upload. When I connect my PC to the modem I get the full 400. When i plug the router to the modem and connect my PC to the router with a ethernet cable I get around 370 to 400 that's good. The problem is wifi I can only get 25 download thats on 5Ghz band. The router is in the latest version online gaming and sometimes video streaming lags alot only on wifi. It used to work fine I would be able to game with wifi with no lag or anything I was also able to get the full 400mbps on wifi. I tried turning the router and modem off several times. Things I have disable
- Qos is disable
- Traffic meter disable
- WMM disable
  • WMM should be enabled, not disabled
    you should roll back the firmware to .52 as both .58 and .60 have wifi problems NG needs to address
    • Th3-0n3's avatar
      Th3-0n3
      Tutor
      I just want to say thanks for replying and WMM I disable yesturday since gaming online got really bad and I read in a netgear page that it helps to disable this. I roll back to the when I get home now should I do a factory reset before i roll back or roll back to the .52 then a factory reset?
    • Th3-0n3's avatar
      Th3-0n3
      Tutor
      I hope this fixes the problem I was about to buy a new router yesturday but man I'll save alot it it works.
      • myersw's avatar
        myersw
        Master
        Two things. Voxel firmware runs well on the r7800 and he has done some fixes that Netgear has not yet. Good firmware in my experience.
        Second thing. Should you decide to get a different router I would strongly urge you look someplace other then Netgear. Netgear really does not seem to have their act together regarding firmware. All releases seem to have major problems right now.
