Havok970's avatar
Apr 17, 2021
Solid orange power LED after firmware update
Greetings,
My son initiated a FW update and after reboot it came up with a solid orange power LED. Cannot even get a link LED on the uplink port using a known good cable.
Troubleshooting:
Never get l2 to known good port on known good router (unlike this POS) on known good cable from uplink on Netgear (aka POS)
I have tried every "factory reset" possibility. If I power it up with the reset button pressed, it changes to flashing white yet NEVER gets l2 with my Mikrotik on known good cable in known good port plugged into the uplink. When I reboot it, it comes back to solid orange power LED. It was on a static and I did remove the lease on my Mikrotik JIC, but still can't even get l2.
After reading countless similar issues, including the fact that they removed TFTP instructions and then put them back up, I have to wonder if they are disabling the uplink port now to prevent people from using the TFTP fix. I can get l2 on the other ports, but no mac shows up, so likely turns into a hub, but no excuse why port LED's on the POS don't work (or why there are not actual LED's on the uplink port, either)
This issue is COMPLETELY AVOIDABLE. The power WAS NOT INTERRUPTED DURING FW UPDATE, which makes me consider the possibility this is PLANNED OBSOLESCENCE, especially combined with the reasoning above.
Flash memory is ridiculously CHEAP now, so there is zero excuse for not having dual FW memory and checksum verification. It wouldn't surprise me if this hardware is capable and they just didn't do it.
I do see "hidden SSID" intermittently broadcast from the device on WiFi analyzer, but cannot connect or even see it from the Nighthawk or Genie apps. By all evidence, Netgear bricked the device on purpose irrecoverably through lack of due diligence at the very least.
  • > [...] Cannot even get a link LED on the uplink port using a known good
    > cable. [...]
       What does Netgear call this "the uplink port"?  If you mean the
    WAN/Internet port, then the "Internet" LED does not behave the same as
    the LAN Ethernet port-status LEDs (and so it does not indicate a simple
    physical link).
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual (at least).  Read.  Look for the
    LED descriptions and "Troubleshoot".
    > After reading countless similar issues, [...]
       The non-psychics in your audience might not know what you've been
    reading.
    > [...] I have to wonder if they are disabling the uplink port now to
    > prevent people from using the TFTP fix. [...]
       Huh?  The TFTP recovery scheme uses a LAN Ethernet port, not the
    WAN/Internet Ethernet port.
          https://community.netgear.com/t5/x/x/m-p/1622096#M102004
    • Havok970's avatar
      Havok970
      Tutor
      I'm somehow unsurprised an alleged "guru" doesn't know "Uplink port" is standard network terminology, or that the uplink port is usually the default management port, and was more invested in insulting my submission than solving the problem. I maintain this problem is 100% avoidable and thus I have REASON for snark. Thanks for nothing, "guru"
      • antinode's avatar
        antinode
        Guru
        > [...] alleged "guru" [...]
           User ranks are assigned by the forum software.  Out of my control.
        > [...] "Uplink port" is standard network terminology, [...]
           I can guess what you mean, or you can use the "standard network
        terminology" used in the Netgear documentation.  Your choice.
        > [...] the uplink port is usually the default management port, [...]
           On _what_, exactly?  Have you read any of the documentation for your
        Netgear router, or are you relying on your vast experience and
        expertise?
        > Model: R7450|Nighthawk AC2600 Smart WiFi Router
        > Model: R7800|Nighthawk X4S AC2600 Wifi Router
        And your router is a what, by the way?
        > [...] more invested in insulting my submission [...]
           Actually, I was simply trying to make some sense out of a very sloppy
        problem description.
        > [...] I maintain this problem is 100% avoidable [...]
           I'd expect that someone could do a better job than Netgear has done.
        > [...] Thanks for nothing, "guru"
           You're welcome.
           "You can lead a horse to water but you can't make him drink."  Or, in
        this case, the Dorothy Parker version might be a better fit.
