greenlife802
Dec 06, 2014Novice
SOLVED: Slow wireless internet passthrough speed after firmware update
So I first purchased a Nighthawk in July 2014 and it was awesome for a while. Then in notice is past couple months my streaming services were skipping and buffering more that usual (which was almost ...
- Jan 21, 2015UPDATE: Yes, I actually tested the speeds with several different devices (an HP laptop, HTC One M7, and Nexus 9) all of them on 5G band, all ac enabled with latest updates. I also used a couple different speed test sites (speedtest.net, comcast speedtest, cnet speed test), inconsistently had the same result across all devices and hosts.
However, I've actually been communicating with Netgear L2 support for last month... beta testing a couple different versions of the Nighthawk's firmware and even spending over an hour on the phone one night with nice guy who told me he was on an island in Southeast Asia, part of the Philippines... that's where Netgear tech support is halfway between China where they build them and Taiwan where the engineers are. After trying every tweak he could think of for an hour and not getting better wireless speeds, he finally gave up and wished me a Merry Christmas lol. Not a one of those beta firmware's made a bit of difference and I loathe the hours they tricked me into screwing around with them!
BUT TODAY they released vR7000-V1.0.4.14_1.1.50 http://support.netgear.com/product/r7000
And to my shock it actually worked! Not only have my high wireless speeds returned (120+ Mbps)
http://www.speedtest.net/my-result/4078979293 (laptop)
http://www.speedtest.net/my-result/a/1131321713 (nexus 9)
http://www.speedtest.net/my-result/a/1131332778 (htc one m7)
but also my previously incompatible Seagate SRD0SD0 (3TB) USB 3.0 external hard drive now works, too. What a bonus! The whole reason I bought the Nighthawk was to use as DLNA server and the monster external HD I picked up 6 months ago just happened to be on the long list of ones incompatible with this finicky router.
But now it all works (at least for now).
P.S. Maybe it's in my head but I swear since this last firmware update when running speedtest now or transferring files (any heavy streaming) I can hear the router making a higher pitched electrical humming/whistling noise, it's a little disconcerting... I'm not sure having my brain fried by overclocked wifi is going to be worth the high speeds in the end... :eek:
shonuffharlem
Nov 23, 2015Tutor
So glad Netgear support replied to my question about why does Internet speed get cut 50% if I turn Dynamic QOS On - NOT! What horrible support.
RStock521
May 04, 2016Aspirant
Absolutely awful support and they want to charge me to troubleshoot this R7000 what is still within it's warranty period. I've tried resetting and a couple different firmware versions and I can't even get 1mbps download. It's at 60 mbps down when I'm connected to my modem. My old cheap $30 router was better! Wish they would release a good updated firmware to fix this common issue.
- JamesGLMay 05, 2016NETGEAR Employee Retired
Hi RStock521,
Did you use the beta firmware for your R7000? If not please try it. Reset the router and manually reconfigure.
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R7000-Beta-FW-1-0-5-62/td-p/1078114
- RStock521May 06, 2016Aspirant
Thank you for the suggestion. My speeds seem to be back up with your suggested firmware, but I'll continue to speedtest in the coming days.
EDIT: After a couple more speedtests, my speeds declined from 50, to 20, and now they're consistently under 1Mbps. Really frustrated with this router at this point.
- JamesGLMay 09, 2016NETGEAR Employee Retired
Hi Rstock521,
Have you reset the router already to factory default and reconfigure manually? And also try to disable the QoS of R7000.
