Hellraiser2167's avatar
Apr 13, 2021
Speeds are slowed down when connected to router R8000
I get 520mbps with my modem hardwired connected to my laptop. When I connect to the router I drop down to 265mbps. Any one have suggestions as to what could be causing the router to knock down my speed almost in half?
  • plemans's avatar
    what modem is it?
    What firmware are you on?
    Have you tried disabling qos, access control, parental controls, and traffic monitoring? (then reboot the modem after disabled)
      • plemans's avatar
        traffic monitoring and parental controls are off?
        Even after disabling them, sometimes a factory reset is needed to re-enable ctf that allows for faster speeds.
        Also, your Arris NVG468MQ is a modem/router combo device
        It can cause a double nat as well as it has its own qos/traffic monitoring.
        https://kb.netgear.com/30186/What-is-Double-NAT
