PL8SWPR's avatar
PL8SWPR
Speeds drops intermittently - Doesn't happen when router bypassed
I have had the router for a couple years.  Warranty expired last week.  No issues until today.  Internet speeds drop from 80 to 2Mbps every few minutes.  Anything I watch buffers routinely.  I am using FIOS and connected through Cat6.  When I connect the FIOS directy from the ONT to a computer, it works fine - no issues.  As soon as I connect back to the router, it doesn't.  Turned QoS off.  No difference.  Same issue over WiFi or Wired.  All devices in the house.
Verizon is blaming the router.  Everything light on the router is green.  No errors, etc.
Could it be the router?  I was using the .36 firmware and upgraded to V1.3.3.140_10.1.75 today to see if that would fix it.
  • michaelkenward's avatar
    michaelkenward
    What actually happens? I'm afraid "it doesn't" could be any number of things.
    Does this ONT have a make and model? Loads of things go under that label, so there could be all manner of box at your end.
    Have you tried a reset on the R7000P?
    • PL8SWPR's avatar
      PL8SWPR
      For the several years (last 2 years with this router) multiple streams (up to 5 or 6), no issues. All of the sudden, streams start buffering if 2 or 3 are going at once. Speed tests show a drop from normal to 2Mbps back to normal. I have a 75/75 connection from Verizon.
      Verizon had us run speed tests when connected directly from their equipment (the ONT outside) to a computer. Since that test showed normal speed, they blamed the router. They also tried to say that 75Mbps was only good for 2 or 3 streams.
      I have upgraded firmware and did a factory reset this morning. Still having issues. I am on the verge of just upgrading the router to the R8000P just to make sure it isn't the router. I have a hard time though believing that with no changes, the router all of the sudden stops handling our normal traffic.
        michaelkenward
        Makes some sense for wifi.
        All those "go fast" claims on the boxes are less impressive when you realise that they don't take account of the growing number of wifi clients that we throw at our routers.
        You can hardly expect a 75 Mbps Internet link to suddenly allow three, or more, wifi devices to connect simultaneously to the Internet and deliver 75 Mbps, or faster, each.
