Munchoba
Sep 13, 2022Tutor
Sporadic loss of internet connection with R7000P
Hi,
For a few months now, my router loses it's lan and wifi connection. I'm not sure where to start troubleshooting. Firmware is up to date.
Any ideas?
thanks
Try putting your helix in router mode and the netgear in access point mode.
to often I see "bridge" mode not function properly.
Just make sure if you leave wifi enabled on the helix to have them on different channels to prevent interference.
Details help.
- what actual firmware version are you on?
- what modem/gateway is it connected to?
- how frequently is it happening?
- does it happen to all devices? or specific to wireless devices?
- when it happens, does it say "connected, no internet" or what actually happens when you're having issues.
- MunchobaTutor
Hi,
Thanks for your help:
- what actual firmware version are you on? v1.3.2.134
- what modem/gateway is it connected to? Our local provider calls it Helix; I bridged it. From provider's site: Branded as “Helix,” the new tech includes the same wireless video set-top and DOCSIS 3.1 WiFi gateway used in the U.S. by Comcast X1 subscribers. According to Lightreading, Videotron is using gateway hardware manufactured by Technicolor using Broadcom chips.
- how frequently is it happening? once, twice a day.
- does it happen to all devices? or specific to wireless devices? All devices . I have 6 wired. TV is affected too.
- when it happens, does it say "connected, no internet" or what actually happens when you're having issues. When it happens, I lose visibility to the Netgear device. I notice there are 3 orange or red lights on far left of Netegar router. Sometimes it'll come back after 5 minutes, other times I have to unplug the router for a reboot.
Thanks
