czarekkb's avatar
Dec 20, 2021
SSID configuration on RAX200
My router model is: Netgear Nighthawk AX12 RAX200. Its Smart Connect feature permits one single SSID to be assigned to all three radios: 2.4GHz, 5GHz-1, 5GHz-2. Instead of using this option, I would like to use one SSID for 2.4GHz radio and another, different SSID for BOTH 5GHz radios.
Router setup web app has indeed permitted me to assign one SSID to 2.4GHz radio and another, different SSID to BOTH 5GHz radios. Does this mean that the router will effectively route the incoming 5GHz connections to either one of the 5GHz radios?
Also, to mention this, from router stats, I can see that, so far, only 5GHz-1 radio is showing data traffic, and there is almost zero traffic on 5GHz-2 radio.
Thank you for reviewing and sharing any potential insights on this!
  • Thank you again for advising.
    Just to share one observation… When I changed the config to use a unique SSID for 5GHz-2 radio, the router traffic stats immediately started to show some traffic on 5GHz-2 radio – without any devices even connected to it yet. It seemed as if as soon as the 5GHz-2 radio started to use its own SSID, it became visibly “active” in router stats view.
    Upon reflection, I will use the setup, where each radio has its own unique SSID. It will allow me to put computers on 5GHz-2 radio and do streaming on 5GHz-1 radio – thus separating “work” traffic (frequent backups over WiFi) from “play” traffic.
    Thank you so very much for all your time and sharing your expertise. MOST tremendously appreciated. Happy Holidays!
  • FURRYe38's avatar
    Router setup web app has indeed permitted me to assign one SSID to 2.4GHz radio and another, different SSID to BOTH 5GHz radios. Does this mean that the router will effectively route the incoming 5GHz connections to either one of the 5GHz radios? Yes.
    Also, to mention this, from router stats, I can see that, so far, only 5GHz-1 radio is showing data traffic, and there is almost zero traffic on 5GHz-2 radio. It's up to devices to pick and chose which frequency they connect too. Some may prefer the 1 radio over the other.
    Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products:
    https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
    Thank you.
    • czarekkb's avatar
      czarekkb
      Tutor
      Thank you so much for advising – most tremendously appreciated. (Also, thank you for pointing out the correct community to post to.)
      In such configuration (e.g., one single SSID for two 5GHz radios), will RAX200 perform any type of load balancing between the two 5GHz radios when connecting the devices to one radio or the other?
      • FURRYe38's avatar
        There maybe some balancing, however again, it's up to devices to pick and choose what signal they connect too...I presume there router helps on some level. To how much, no idea.
        Something to test out. If you name the SSIDs differently then you can help force some devices to specific radios.
