jory12's avatar
jory12
Starlink compatibility with a mesh and router
So I have the round Starlink dish. I replaced the router with a Netgear one so that I could link to a mesh (AC1900 WiFi Mesh Extender Nighthawk® Dual-band WiFi Mesh Extender), but I just cannot get my router to find my mesh. The mesh shows up, but it wants me to disconnect from the router. I've tried that, and various other things. Is there something I'm doing wrong because of Starlink settings? Is there a different, easier mesh to use? Thank you!
  • Thanks everyone! I just had to buy a newer router for my garage and turn that into an access point. Easy peasy.
  • FURRYe38's avatar
    What NG router are you using?
    This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
    2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
    https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
    3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
    • jory12's avatar
      jory12
      Thanks. I don’t really understand that. Others say they plug and go. I must have the wrong setup. I think I need a mesh only system - multiple meshes? No router? The nighthawk app can not identify the mesh. It’s the R7450 nighthawk router.
      • FURRYe38's avatar
        You'll need to ask the ISP if a Netgear router and be used in place of there router.
  • plemans's avatar
    1. You said you replaced the starlink router with a netgear one but not a model. what actual router are you using? (model)
    2. what extender are you using? (hint ac1900 is a speed, not a model. look at its label)
    3. Not sure if starlink supports a direct connection to a netgear router without their starlink setup. Did you check with them?
