SGoulding
Nov 01, 2021Tutor
Sudden drop in throughput
Late last week, noticed internet slow. Troubleshooting eliminated everything except the Router.
NBN connection is AussieBBS 250Gb download speed.
For the last 3 days best performance has been 30Gb download, with most avg 17Gb download. Upload speed not affected, ping times normal (9-11ms)
Have checked logs nothing seems amiss.
Latest firmware uptodate.
Scratching head as to what's wrong...
Ideas Anyone ?
A couple things.
1. I think you mean Mbps. not Gig
2. what firmware is on the r8000?
3. what modem/gateway/ont is the R8000 connected to?
4. did you do anything that might have changed it? (moving stuff around, etc)
Yep - my bad, Mb not Gb download
Firmware = V1.0.4.76_10.1.82 (Latest version) Been on router & working fine since released a while ago.
Nothing chas changed, no reloactions, no different equipment, nothing changed.
Router connected to NBN equipment (Arris CM8200)
try factory resetting it.
Push and hold reset for 7-15 seconds while powered on.
Then during the install, make sure to leave qos, access control, traffic monitoring, and parental controls all disabled.
