andrewv's avatar
andrewv
Tutor
Aug 16, 2021
support case won't create
the website will show + for support options
However once + is pressed it would show for a second a list of options but then close automatically
so there is no way to select any of the listed options
  • just tried it on mine and it worked.
  • plemans's avatar
    have you tried a different web browser or pc/laptop?
    • andrewv's avatar
      andrewv
      Tutor
      tried few computers/ browsers - chrome, but also chromium at different devices
      • plemans's avatar
