cgadam's avatar
cgadam
Follower
Jul 03, 2017
The application “NETGEAR USB Control Center Installer.app” can’t be opened. (MAC)
I tried to install the Ready SHARE Printer MAC V2.36 software for MAC (10.12.5):   Uncompress the ReadySHARE USB Printer MAC_V2.36.zip file Uncompress the ReadySHARE USB Printer MAC_V2.36.rar fil...
  • gensym's avatar
    Aug 01, 2017
    Hello,
    apologies for perhaps stating the obvious, but it might be that your issue is because of the macos Gatekeeper (see: https://support.apple.com/en-us/HT202491).
    => Did you try to Control-Click the app, and then selecting "Open" from the pop-up menu?
    (The short of it: To protect you from executing downloaded content by accident, macos requires to explicitly acknowledge it the first time you open it. This is done by:
    1. In Finder, Control-click or right click the icon of the app.
    2. Select Open from the top of contextual menu that appears.
    (apologies for late posting, but I only just joined…)
    it would be great if this was of help -- and otherwise, please forgive the "noise".
