ill
Jun 10, 2017Aspirant
Trouble with Denon AVR-X4300H Accessing Nighthawk X4S AC2600 R7800 Home WiFi Network
Purchased a Denon AVR-X4300H and I'm trying access my home wifi network. I'm using Netgear Nighthawk X4S AC2600 Model R7800. Is there anyone on this forum familiar with the unit? Thank you for help.
- FURRYe38,
I went into Setup\Network\WiFi Setup and the AVR scanned for wifi networks. When it displayed mine I entered the password for the 5GHz band. That was it.
- William10aMaster
From the instructions it sounds simple on the Denon unit scan for wifi signals and select your's and enter your password for the network.
Here is a link to denon's manual https://usa.denon.com/us/product/hometheater/receivers/avrx4300h
I hope this by the look at page 237 in the manual good luck .
- illAspirant
Thanks William10a. I figured it out last night shortly after I began this thread. I was a bit over tired and not thinking clearly.
Does the AVR have a wired LAN port as well? I recommend using LAN port for best performances if your goingto use an AVR.
- William10aMaster
From I saw yes it has a 100mb wired lan port depending where the amp is located and the router located yours may be the best answer since in the end it all comes down to a static ip address on the network for the amp's network interface.
In fact it is on page 86,87 even tells how to connect and set up in the owners manual.
I guess 100Mb is good enough.:smileyfrustrated: I presume no streaming with the AVR.
- illAspirantYes, I know. I have it connected to my pc. Using Windows Media Player 12. The AVR is connected to it via the network. Using it as an online music server. It's a great piece of hardware.The video will come from an LG OLED65E7P in August. It can connect with wireless speakers in other rooms. Eventually will connect a Rega turntable to the AVR. It's another reason why I purchased it.
- illAspirantFURRYe38,
I went into Setup\Network\WiFi Setup and the AVR scanned for wifi networks. When it displayed mine I entered the password for the 5GHz band. That was it.- FURRYe38Guru - Experienced User
Awesome. Enjoy.:smileywink:
- illAspirantThank you.
:smileywink:
