R7KUser
Mar 17, 2016Aspirant
Two R7000 Trying for BIG FAST home network
I tried to squeeze the idea into the subject. "Regular" home and internet needs: Home Theatre (Xbox, PS, BluRay, TV, etc) Tablets Laptops Smart Phones I have a cable modem and pay for 10...
- Mar 18, 2016
When you use the AP mode of the router, it will disable features that are used in router mode, so you won't need to go through disabling features.
- you can decide whether you give the AP a static address or let the DHCP Server do it for you.
- Wireless channel settings need to be different on both R7000's
- SSID's can be the same, if your intent is to roam devices (some devices roam better than others).
- router passwords can be the same
- wifi passphrases should be the same (ensure they are STRONG passphrases - no dictionary words - easily hacked).
- Yes, leave WMM on.
netwrks
Mar 17, 2016Master
If you have a modem only device from your ISP, one R7000 should be in router mode, and the other should be in AP mode (best solution - ethernet connection back to your base R7000 router). Powerline is hit or miss. You may have to move the powerline adapters around to test best connectivity. If you are in North America, channel 5 is a bad selection, as it is an overlapping channel and will cause additional grief for you, and, your neighbours. Don't leave 2.4ghz in auto (pick a non-overlapping channel (1,6,or 11)). make sure WMM is enabled on your router.
R7KUser
Thank you for the update.
I neglected to mention WMM was enabled per another read reccomendation.
I did not know about channel 5 (I am in North America), I will make that change.
I will also experiment with the powerline, there may be an option to move the cable company internet drop line to a better location.
If that happens, I wouldn't need the powerline adapter.
Lots of things to play with, I'll be working on the changes tonight.
Thanks again for the info.
Also, FWIW - if there are any other settings that I missed (like the WMM) please feel free to let me know :)
Thank you.
