R7KUser's avatar
R7KUser
Two R7000 Trying for BIG FAST home network
I tried to squeeze the idea into the subject.   "Regular" home and internet needs: Home Theatre (Xbox, PS, BluRay, TV, etc) Tablets Laptops Smart Phones   I have a cable modem and pay for 10...
  • netwrks's avatar
    netwrks
    Mar 18, 2016
    When you use the AP mode of the router, it will disable features that are used in router mode, so you won't need to go through disabling features.
    - you can decide whether you give the AP a static address or let the DHCP Server do it for you.
    - Wireless channel settings need to be different on both R7000's
    - SSID's can be the same, if your intent is to roam devices (some devices roam better than others).
    -  router passwords can be the same
    - wifi passphrases should be the same (ensure they are STRONG passphrases - no dictionary words - easily hacked).
    - Yes, leave WMM on.
