captclam1
Nov 29, 2020Aspirant
Two X10s One in AP mode 802.11s supported?
I currently have my X10 as my router and two R6250R2 APs in AP mode (wired backhaul). Unfortunately, I have the world's worst handoff. I could replace two of the APs with one X10 (R9000) (flamethrower...
- Nov 30, 2020
In AP mode, the R9000 doesn't use smart roaming. Even netgears extenders only support smart roaming while running in extender mode. Switch them to access point mode, and it doesn't roam properly.
I'd probably stick with the orbi setup if you're wanting seamless roaming.
Nov 30, 2020Guru - Experienced User
