janzend
Jan 10, 2015Follower
Unable to enable wireless
This morning the wireless went out on my router and I'm unable to turn it back on. When i go to the basic page is shows wireless off and a yellow caution sign on the setting, see attached. I have rese...
- Jan 18, 2015The second to right LED on the top is actually a button that disables wireless. If you hold it down for 5 seconds, it will disable wireless on the device, and will show it disabled in the GUI but there's no way to re-enable it. To re-enable it, hold down the button again for 5 seconds, the lights for wireless on the left will turn on when it is back on.
I was cleaning yesterday and moved the router behind my TV, and the TV was just resting on top of it. I was using it all day but at some point apparently the TV moved enough to push the button... Kind of weird there's no entry in the log of when this is pushed though, too.
Babylon5
Jan 11, 2015NETGEAR Employee Retired
Have you checked the router page ‘Advanced’ – ‘Advanced Setup’ – ‘Wireless Settings’ to see if ‘Enable Wireless Router Radio’ is checked for both 2.4GHz and 5GHz bands?
