janzend
Jan 10, 2015Follower
Unable to enable wireless
This morning the wireless went out on my router and I'm unable to turn it back on. When i go to the basic page is shows wireless off and a yellow caution sign on the setting, see attached. I have rese...
- Jan 18, 2015The second to right LED on the top is actually a button that disables wireless. If you hold it down for 5 seconds, it will disable wireless on the device, and will show it disabled in the GUI but there's no way to re-enable it. To re-enable it, hold down the button again for 5 seconds, the lights for wireless on the left will turn on when it is back on.
I was cleaning yesterday and moved the router behind my TV, and the TV was just resting on top of it. I was using it all day but at some point apparently the TV moved enough to push the button... Kind of weird there's no entry in the log of when this is pushed though, too.
Sunscape
Jan 24, 2015Aspirant
I had the same issue. Backed up config and then reset to factory settings. All worked fine again. I manually re-added the changes to config and still worked (Apart from the ongoing frequent rebooting bu that is a separate issue). Backed up that config and then reloaded my original config. Sure enough wireless radio lights went out and no way to enable them as they still showed enabled in the UI. Reverted to "new" backup and all working again. Did this a few times to make sure. I was going to log it as a bug but as the random rebooting got so annoying I gave up and returned the unit to the retailer.
So - Reset to factory and then manually rebuild your settings. Backup the config a few times along the way if you are changing many items.
