DerekJames
Nov 12, 2021Aspirant
Unable to join network
I've got a bunch of devices connected to my network and they are ruuning great. I bought a new iPad mini and whwn i try to connect, it says "unable to join network".
Since there is no other inducation of error, I don't know how to fix it. A guest came over with another iPad, and same thing. But my laptop is connected fine, hence my ability to enter this message. :-)
Try setting manual channel 1, 6 or 11 on 2.4Ghz
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Are you sure the password on the pads is correctly entered?
Try the Forget this Network, turn OFF the wifi radio for 5 seconds then turn back on and try to re-connect.
How is the router configured for wifi settings?
What modes are you using?
What channels are you using?
What security mode do you have set on the router?
- DerekJamesAspirantSolved by joining one of the 5G radios. Must be something weird with 2.4. For channel, it is set to Auto.
Enjoy. 📡
