SKlinknagel
Jan 01, 2016Aspirant
Unidentified Wifi netwerk: NETGEAR89-Arlo_246968
Hallo.
I coudnt find anything inside the forum. So here it goes
Installing the new firmware V1.0.6.28_1.1.83 and after activating the Smart Connect functon i have a extra wifi.
I cant find it anywhere inside the settings, and i also cant login with my normal password.
when i power down my Nighthawk also this netwerk will shut down.
My normall wireless wifi setup is working normally.
Can anyone help me?
Thx
You should have it under "Basic" settings, If you don't try restarting your router...
You can then disable the Arlo network.
- SKlinknagelAspirant
Oke! Thx
The solution was to change over the settings to Englis. It doesnt show in the Ducth (netherlands) langues.
