vmhoffers's avatar
vmhoffers
Updating Firmware R6400 v2
UPDATED:  While I was awaiting a response, I decided to try logging out of the 192.168... and log back in and start all over again using the downloaded firmware.  I worked this time.  Hope this helps someone else.
I am trying to update my firmware on my Nighthawk AC 1750 R6400 v2 (V1.0.4 102_10.0.75)  I am doing this wired not wirelessly.
I logged onto the router and there was a purple button right on the main screen saying new firmware was available.
I clicked on it, and it said that it was connecting and to wait.
Minutes went by and nothing happened other than in the lower left corner of my browser, Firefox, it would flash very quickly that it was "Transferring Data".  That's all I could read before it disappeared again.
I canceled.
Then I went to Netgear and manually downloaded the latest firmware version for my router  1.0.4.120 10.0.91
Extracted all the files.
On the Netgear tab, I clicked Advanced
Selected Firmware Update
Selected the .chk file from the extracted folder
And the same thing is happening.
I have turned off my VPN and Firewall, to no avail.
It has been over 15 minutes.
What else can I do to try to update the firmware?
Thanks for any assistance.
    I canceled.
    To update your router’s firmware, follow the instructions in your router’s user manual. To view your router’s user manual, visit the following support page https://www.netgear.com/support/product/R6400v2.aspx#docs
    • vmhoffers's avatar
      vmhoffers
      I put the model number in the text of the message since I could not find it in the drop down list of options. ". Nighthawk AC 1750 R6400 v2"
      I DID follow the instructions in the manual as indicated in the text of the original message (2nd attempt), which was unsuccessful.
      As I mentioned, logging off and restarting the whole process allowed the update to happen successfully though I am not sure why.
      Thank you
      • FURRYe38's avatar
        Thats just a tag that gets included with your post so users know what model NG product you have. Does not direct your post to specific router model forums.
        Hopefully someone in that forum will be able to help out.
        Also review NG download page for your model router and any FW update help there including the user manual.
        Good Luck.
    I canceled.
    To update your router’s firmware, follow the instructions in your router’s user manual. To view your router’s user manual, visit the support page
