svr2000's avatar
svr2000
Tutor
Apr 19, 2026
Upgrade firmware
I’m trying to update firmware for my 7800 from the admin portal. Even though there’s a newer version available it is saying no new update available. Is that a common issue?
1 Reply
  • FURRYe38's avatar
    Yes. R7800 is EoL and so no longer on NGs auto update services.
    So if you want new FW, you'll need to manually download it and install it with a PC and web browers.
    Also refer to Voxels continued FW as well.
    Good Luck.
