svr2000
Apr 19, 2026Aspirant
Upgrade firmware
I’m trying to update firmware for my 7800 from the admin portal. Even though there’s a newer version available it is saying no new update available. Is that a common issue?
1 Reply
Yes. R7800 is EoL and so no longer on NGs auto update services.
So if you want new FW, you'll need to manually download it and install it with a PC and web browers.
Also refer to Voxels continued FW as well.
Good Luck.
