d0gg
May 13, 2018Apprentice
UPNP no longer works
I just updated to Firmware V1.0.3.16
After the router completed the update, UPNP no longer works.
I have tried rebooting the router several times but the port is not being automatically ...
- May 13, 2018
Im sorry. Damn forum is a beast to navigate.
BIG_DOG
May 13, 2018Luminary
agh, this is for the XR500 pro gaming router, you are in the wrong forum sction.
d0gg
- AudiTunerMay 13, 2018Star
Same issue here as the OP. Have tried doing a factory restore and manually entering all settings again but that does not fix this issue.
Also, when manually entering all settings after a factory restore, my two Android devices (along with two separate wireless 2.4GHz only devices) will not connect to my WiFi networks. I have tried disabling "smart network switching" on the Android devices but that does not work (it says there is "no internet connection" on both the 2.4GHz and 5GHz wireless networks). This issue seems to crop up if I apply ANY setting changes to the LAN Setup page (IP reservations, DHCP range, etc.).
Neither of these two issues (uPnP not working and cannot connect to some devices) are present in v1.0.3.10, only in v1.0.3.16.
