01R
Nov 02, 2014Luminary
UPnP on or off ?
if u ask at security forums and almost every one says to turn it off for security reasons ok now but if u play games on xbox live and use the port forwarding every now an then the router gets confused...
- Nov 03, 2014If you can trust all the devices on your LAN, i.e. are sure that none will have any malware that could take advantage of UPnP then you can turn it on, one advantage of UPnP is that ports are only open when in use. Have you tried running with UPnP on, does it help?
RogerSC
Nov 07, 2014Virtuoso
Sounds good to me...I don't use UPnP, so I always disable it. No reason to have it on, and there have been some weird little exploits using security holes relating to it in the past. So if I disable it, it's not something I have to consider if things go wrong.
