cm55
Nov 22, 2016Aspirant
USB Sharing type FTP (via internet) suddenly stopped working
Hi, I have been sucessfully using the FTP via internet setting until one day it just stopped working. After extensive debugging I simply cannot explain it! The URL is ... ftp://myrs.mynet...
- Dec 12, 2016
It's OK I found the problem somewhere I wasn't expecting - my ISP implemented CGNAT :-(
TheEther
Nov 22, 2016Guru
Try a factory reset and reconfigure from scratch.
cm55
Nov 26, 2016Aspirant
Done, made no difference!
- TheEtherNov 26, 2016Guru
Is there any chance that your public IP address has changed?
- cm55Nov 28, 2016Aspirant
No, just double checked and still the same, to confirm this does not work...
Where it is set up as so...
- JamesGLNov 29, 2016NETGEAR Employee Retired
Hi cm55,
Can you try to access the HTTPS(via internet) if you can access it or not. If not, try reloading the previous firmware, reset and reconfigure.
http://kb.netgear.com/app/answers/detail/a_id/30766?cid=wmt_netgear_organic
JamesGL
Community Team
