DrBlingDaddy's avatar
DrBlingDaddy
Using CM1150V with RAX120. Is port aggregation possible?
For normal operation of the two devices for internet it looks as if the WAN port on the RAX needs to be connected to port one on the 1150. But in order to use port aggregation the RAX, ports 1 and 2 must be used (not the WAN port). Would connecting to ports 1 and 2 on the RAX to the ports 1 and 2 on the 1150 work for maximizing internet speed? I know that ports 1 and 2 on the 1150 are used for port aggregation. Thanks!
  • Okay, so I figured it out. I needed to enable WAN aggregation on the RAX under "Setup", "Internet Setup", and "Ethernet Port Aggregation" under "Advance" on the 1150.
    • DominicanMacPro's avatar
      DominicanMacPro
      Apprentice
      So want is the difference? I currently have cm1200 port 1 plugged into wan on the rax and port 2 on modem plug into port lan 1. Creating WAN aggregation.  What are the benefits of port aggregation?
      • antinode's avatar
        antinode
        Guru
        > Okay, so I figured it out. [...]
           Perhaps.  Perhaps not.
        > [...] What are the benefits of port aggregation?
           I'll bite.  If you don't know, then why bother doing it?
           The idea is that two 1Gb/s Ethernet links can cary data at
        (approximately) twice the rate of one 1Gb/s Ethernet link.  If your
        Internet service provides more than 1Gb/s, then an aggregated link
        between the modem and the router should provide more speed over that
        path.
           Visit http://netgear.com/support , put in your model number, and look
        for Documentation.  Get the User Manual.  Read.  Look for "Ethernet Port
        Aggregation".
           I know nothing, but as I read the User Manual for a "Nighthawk AX12
        12-Steam AX6000 WiFi Router" (carefully proofread, obviously -- I use
        only internal-combustion routers, not "Steam", and certainly not
        "12-Steam"), I see instructions for aggregating two _LAN_ Ethernet
        ports.  If it's possible to use aggregation on the WAN/Internet side of
        an RAX120, then it's not obvious to me.
