Smokie365's avatar
Sep 20, 2016
VPN setup
I'm sorry if this has already been asked but I am having huge trouble with virgin media YouTube and Netflix buffering, can I set up a vpn on my Nighthawk router so that everything on my network goes through a VPN? A lot of my devices are not computers so clients can not be installed on them, if the router is set with the VPN would all devices connected to it be utalsiaing the VPN? Obviously there ip would be in my range but outside traffic will think it's coming from somewhere other than Virgin media servers.
Thanks for reading
  • JamesGL's avatar
    JamesGL
    Sep 22, 2016
    Hi Smokie365,
    That is correct. The router can only be set as the VPN server via the OpenVPN and passthrough if using other VPN service but will be able to do configuration as a client.
    JamesGL
    Community Team
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi Smokie365,
    The router can serve as the VPN server via the OpenVPN but it cannot be set as the VPN client. If you have other VPN server then the router can be a VPN passthrough.
    JamesGL
    Community Team
  • Thanks James
    So what I am looking for is not available unless I go with ddrt or something similar??
    • JamesGL's avatar
      JamesGL
      Hi Smokie365,
      JamesGL
      Community Team
