tamme_tekkel
Jan 11, 2018Aspirant
Wait to long ?
Hello
If i whant change something for example wifi password en save it. It takes about 1 minnut
For this action. In this minut i can do nothing else. My r7000 do not work this way.
What ido wrong here??
- Have you update your new NETGEAR?
- Its take for changing password for my R9000 between 10 and 15 second!! I’m sure you have something not going on!
- tamme_tekkelAspirantHello
I buy a netgear router and connect.
Afther connect i change my wifi name and password. Than save.
I try the same by my R7000. Go to fabrik changes. And do the same. This takes 10 a 15 seconds. Why the R9000 not. For example portforwarding is 1,5 minut.
I do not now or this good. Or what i must do?
For the price i thought that i can exspect some quicker than the R7000.
Maybe wrong touhgt?- Have you update your new NETGEAR?
