Totti
Feb 20, 2014Aspirant
Wake On Lan with R7000
Hi, i get my new R7000 today and have an Asus RT-N66U before. The Asus WOL work fine but i found no way to use WOL with the R7000. With the R7000 i cant use 255.255.255.255 as Subnetmask to use ...
- Aug 10, 2015
Hi Riker.
Now that I've confirmed that the removal of my solution was a moderation, I'll try repeating it from memory (I was actually using this thread, bookmarked, to remember how to do it).
- Download TelnetEnable from here: https://github.com/LuKePicci/NetgearTelnetEnable/blob/master/binaries/windows/telnetenable.exe?raw=true
- Open a DoS/Command Prompt on a PC directly connected to the same LAN and type 'telnetenable.exe <router-IP> <router-MAC> admin <admin-password>'
- Telnet to the router
- Type 'arp -i br0 -s x.x.x.x mm:mm:mm:mm:mm:mm' where x.x.x.x is the WoL destination IP address (not .255) and mm... is
the WoL destination's MAC address
You should then have a static ARP entry in your router. Set up forwarding of port 9/UDP to your device you want to wake and it should work.
- Dave
Atin90
Feb 21, 2014Aspirant
Best way to use remote WOL is to port forwarding port 9 (usually used for WOL) to one PC on the local network and if you wish to WOL other PC's on the same network, install LogMeIn or TeamViewer (there are other programs similar to these) on all the PC's that you wish to WOL. Once one PC is ON, any other PC can be WOL with one of these VNC programs.
