Totti
Feb 20, 2014Aspirant
Wake On Lan with R7000
Hi, i get my new R7000 today and have an Asus RT-N66U before. The Asus WOL work fine but i found no way to use WOL with the R7000. With the R7000 i cant use 255.255.255.255 as Subnetmask to use ...
- Aug 10, 2015
Hi Riker.
Now that I've confirmed that the removal of my solution was a moderation, I'll try repeating it from memory (I was actually using this thread, bookmarked, to remember how to do it).
- Download TelnetEnable from here: https://github.com/LuKePicci/NetgearTelnetEnable/blob/master/binaries/windows/telnetenable.exe?raw=true
- Open a DoS/Command Prompt on a PC directly connected to the same LAN and type 'telnetenable.exe <router-IP> <router-MAC> admin <admin-password>'
- Telnet to the router
- Type 'arp -i br0 -s x.x.x.x mm:mm:mm:mm:mm:mm' where x.x.x.x is the WoL destination IP address (not .255) and mm... is
the WoL destination's MAC address
You should then have a static ARP entry in your router. Set up forwarding of port 9/UDP to your device you want to wake and it should work.
- Dave
JAMESMTL
Feb 25, 2014Novice
I use DD-WRT on my R7000. For WOL from WAN what I do is this:
1. Connect to router from WAN via PPTP using ipad, cell or whatever
2. Using any browser I navigate to the router's WOL page (192.168.x.1/Wol.asp)
3. Press the wake up button for the device I want to wake up
No special software is required as DD-WRT has built WOL functionality. I also do not expose the router's GUI directly to the WAN.
DD-WRT also has a built in WOL daemon which can be set to wake up devices every x period of time.
If you wish to forgo step 1 you can enable the router's GUI to be accessible via WAN, something I prefer not to do.
