Totti
Feb 20, 2014Aspirant
Wake On Lan with R7000
Hi, i get my new R7000 today and have an Asus RT-N66U before. The Asus WOL work fine but i found no way to use WOL with the R7000. With the R7000 i cant use 255.255.255.255 as Subnetmask to use ...
- Aug 10, 2015
Hi Riker.
Now that I've confirmed that the removal of my solution was a moderation, I'll try repeating it from memory (I was actually using this thread, bookmarked, to remember how to do it).
- Download TelnetEnable from here: https://github.com/LuKePicci/NetgearTelnetEnable/blob/master/binaries/windows/telnetenable.exe?raw=true
- Open a DoS/Command Prompt on a PC directly connected to the same LAN and type 'telnetenable.exe <router-IP> <router-MAC> admin <admin-password>'
- Telnet to the router
- Type 'arp -i br0 -s x.x.x.x mm:mm:mm:mm:mm:mm' where x.x.x.x is the WoL destination IP address (not .255) and mm... is
the WoL destination's MAC address
You should then have a static ARP entry in your router. Set up forwarding of port 9/UDP to your device you want to wake and it should work.
- Dave
fordem
Jul 30, 2014Mentor
SntaCruz83 wrote: I think this needs to be clarified a little. I'm not a pro on the topic by any means, but I've dealt with my fair share of trying to wake my computer up remotely when I'm not on the LAN.
Feel free to correct me if I'm wrong on any of this...like I said, this is all conjecture based on my own trial and error.
Fantastic!!
I give you an A+, at least up to the reasons why Wake-on-LAN across the internet does not work, I don't know about the Asus Android app, so I can't comment on that.
A little clarification - for Wake-on-LAN no support is required in the modem/router - because it is purely LAN~LAN activity and works with a network broadcast - you can do Wake-on-LAN on a LAN with no router.
On the other hand - Wake-on-LAN across the internet requires the router to have a feature called "ip directed broadcast" enabled, and the IETF now requires this be disabled as the router's default setting and most manufacturers simply don't provide a way to enable it.
