Totti
Feb 20, 2014Aspirant
Wake On Lan with R7000
Hi, i get my new R7000 today and have an Asus RT-N66U before. The Asus WOL work fine but i found no way to use WOL with the R7000. With the R7000 i cant use 255.255.255.255 as Subnetmask to use ...
- Aug 10, 2015
Hi Riker.
Now that I've confirmed that the removal of my solution was a moderation, I'll try repeating it from memory (I was actually using this thread, bookmarked, to remember how to do it).
- Download TelnetEnable from here: https://github.com/LuKePicci/NetgearTelnetEnable/blob/master/binaries/windows/telnetenable.exe?raw=true
- Open a DoS/Command Prompt on a PC directly connected to the same LAN and type 'telnetenable.exe <router-IP> <router-MAC> admin <admin-password>'
- Telnet to the router
- Type 'arp -i br0 -s x.x.x.x mm:mm:mm:mm:mm:mm' where x.x.x.x is the WoL destination IP address (not .255) and mm... is
the WoL destination's MAC address
You should then have a static ARP entry in your router. Set up forwarding of port 9/UDP to your device you want to wake and it should work.
- Dave
ViperGeek
Jun 22, 2015Apprentice
Hello.
I'm running V1.0.4.30_1.1.67 and just tried it again after a fresh reboot (which resets the telnet listener). Worked again:
Here's the MD5 of the telnetEnable.exe I'm using:
I'm also directly adjacent to the Ethernet and used the MAC address of the Ethernet port of the R7000, as reported by 'arp -a'.
- Dave
C:\>telnet 192.168.0.1
BusyBox v1.7.2 (2015-05-26 08:38:17 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
C:\>md5 telnetEnable.exe
MD5(telnetEnable.exe)= 90186d9b6dfe7f414af099f7663e53e4
- Dave
